Minolta 7hi
Discussion in 'Photography Forums' started by tobias3, Aug 23, 2004.
  1. tobias3
    tobias3
    Aug 23, 2004
    276
    +4
    anyone had any experiences with one of these? Looking to buy one as it's the closest i can find to a dslr without breaking the bank!!!
    Also considering a fuji finepix s7000...
    any views would be most helpful!
    thanks
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Hello and welcome to the forums! :hiya:
    I bought one of these almost exactly a year ago. I'm absolutely delighted with it. It offers so much control and flexibility. Output is excellent and the optics are top notch. My only criticism is that the EVF isn't brilliant for manual focusing as it isn't very high resolution. Are you aware that the camera has been supeceded twice? First by the Dimage A1 and now the A2. Both cameras use the same optics as the 7Hi but add a useful anti-shake feature (for those 200mm zooms!). Check out the review of the 7Hi here
    Hope this helps ;)
    edit: forgot to mention the 7Hi takes AA batteries (handy if they run out at an inconvenient moment... the A1 and A2 use a proprietary Li-Ion battery) also I personally would discount the Fuji, I'm not a fan of their Super CCD technology, in my opinion interpolation is not a good thing in photgraphy no matter how cleverly done.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    I've got the origional Dimage 7 and agree that it and its newer models (7i & 7Hi) are great cameras that are about as close as you can get to DSLR without the big money.
    The only down side of these cameras is the fact that they eat batteries at an alarming rate. But as RCT said they do use standard, make that cheap, rechargeable AA batteries. So you just need to make sure you carry at least 1 full set of replacements.
    Mark.
  4. tobias3
    tobias3
    Aug 23, 2004
    276
    +4
    many thanks guys. I think i may go with the 7hi i think for the money. Does anyone know of any alternatives? ANything close to dslr would be a possibility.
    Many thanks in advance and thankyou for the kind welcome to the forum!
  5. tobias3
    tobias3
    Aug 23, 2004
    276
    +4
    any other suggestions i could look at?
  6. martynk
    martynk
    I've got the 7i and largely agree with the previous comments - excellent camera but I,m having a few problems. (1) The EFV is pretty hopeless for manual focussing and I rely on the autofocus function. This is usually OK, but I just can't get the hang of the macro mode at either the tele/wideangle setting. I often resort to taking multiple shots using spot autofocus hoping for a couple of decent images, or shooting from short, normal, range at high definition and zooming in/cropping in Photoshop. Any advice? (2) The barrel/pincushion distortion at the 28mm equivalent is grotesque - particularly on architectural subjects. (3) I have an ongoing problem with blue sky burning out to white - mixed compositions, usually buildings and sky in background. The light here (Johannesburg, nearly 6,000 ft above sea level) is very harsh from about 10am - 3.30pm with extreme levels of UV and I've tried using Skylight and polarising filters but it doesn't seem to make much difference. Never had this problem with 35mm SLRs, but it is exposure issue? Can anyone offer any suggestions?
  7. nealgs
    nealgs
    hi tobias3,
    did you choose anything in the end?? i've been looking at the 7hi myself as an upgrade, looking at 2nd hand due to limited funds, but wanting something DSLR like.
    Gary
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    I'm thinking of selling my origional Dimage 7 as I now have a full DSLR. If interested then let me know.
    Mark.
  9. nealgs
    nealgs
    thanks for the info Mark, what would you be looking at for it? and what does/would it come with
    cheers
    Gary
  10. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    You have PM :)
    Mark.
