minipod speaker help please
Discussion in 'Home Cinema Speakers' started by noyce, Dec 24, 2003.
  1. noyce
    noyce
    Aug 10, 2003
    179
    16
    England
    I have just recieved my blueroom minipod 5.1 speakers but when i opened my subwoofer the power supply that has come with it is not a standard plug, it has two round prong like sockets which to me looks identical to those found on some electric shavers.
    Has anyone any ideas as i would really appreciate it.
  2. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    If its a european model then it would come with this type of plug. Check that the voltage is 220 or 240 and if it is then all you need to do is cut off the two pin plug and fit a 13amp 3 pin plug. (Don't try a shaver adaptor as it probably has a 1 amp fuse and will blow) The cables will be coloured blue(neutral) and brown(live).
    Even better, if the mains cable is a plug in type (figure 8 or IEC 3pin) then just get a new cable.
  3. noyce
    noyce
    Aug 10, 2003
    179
    16
    England
    Thank you so much for the advice, you saved my christmas!
    Much appreciated.
