minimum viewing distance for a projector/ bundled cables
Discussion in 'Projectors, Screens & Video Processors' started by ibster, Jan 6, 2003.
  1. ibster
    ibster
    Aug 7, 2002
    332
    Coventry
    +12
    Hi guys,
    im thinking about getting a PTA100 soon but i was wondering whether my room was too small. I have been to projector central to check out image sizes ets but i just wanted some personal opinions,
    The seating area to the wall where i want to project my image is only 9-10 feet, is that far enough ? I ideally want to project the image from a shelf above me as i cant mount it on the ceiling due to some light fittings. What is the maximum image one would recommend from this type of viewing distance ?
    Also on another note, what cables normally come supplied with the projector ?
    thanx in advance
    ibster
  2. Underscore
    Underscore
    My viewing distance is approx. 1.8x the screen WIDTH (5' screen viewed from 9') and that is fine but I wouldn't want to view it from too much closer. Whether you can do this from a shelf above you depends on the lens on the projector. My Sanyo Z1 can throw from 1.35 - 1.6x the screen width, so wouldn't be able to but your PJ may be different...
    My PJ came with a mains lead and a short composite cable. Again, yours will probably be different.
    HTH,
    _
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,467
    Windsor
    +1,044
    for the AE100, the minimum and maximum sizes are:
    9ft away: Min 5.4ft wide; Max 6.7ft wide
    10ft away: Min 6ft wide; Max 7.4ft wide
    I'd recommend not sitting any closer than 1.5x screen width, so if you are 9ft away, a 6ft screen sounds about right. The measurements above are from the lens to the screen, so bear in mind the length of the projector too.
