Minimum Spec For HTPC???
Discussion in 'Desktop & Laptop Computers Forum' started by JATH, May 19, 2004.
  1. JATH
    JATH
    Could anyone give me an idea of the minimum spec PC needed to run a Sanyo Z1 projector.
    Was just wondering what cpu speed Etc. is needed?
    Thanks.
  2. Kramer
    Kramer
    Really depends what you want to do with your HCPC. For DVD alone, anything circa 1gHz is fine. Hardware acceleration on your graphics card will do some of the work also.
    If you're looking at capture cards (Dscaler software etc.) or hi-def material (WMVHD), then you'll need far more processing power.
    Try a search here - plenty of previous threads about this - interesting reading.
    Moved to HCPC forum.
  3. JATH
    JATH
    Thanks for that
