minimum speaker distance
frankie13
whats the minimum distance for 7.1 side surrounds from rear backs, is 1meter enough or should i move them a bit more forward
fayeanddavid
Would depend on your listening position I would suggest.
The sides can be either side of you (especially with rears in play) or slightly behind you; if that can be accommodated then that should fix the final position for them
If this was the case what would then be the distance; not that I am sure it is relevant as long as the basics are adhered to?
frankie13
seating in middle of room say 1meter from back wall, sides level with me is this enough space or should i move seating forward along with sides to about 2meters
fayeanddavid
Need also to think of your viewing distance, you haven't mentioned that, but one to one and a half metres should be fine.
If you can experiment with those distances before finally fixing would be even better.
