Hi guys/lasses I am looking at the BT broadband basic service at £19.99 a month but I would like your opinions as to whether a 512kb connection is fast enough or whether I would be missing out loads compared to a 1mb connection. Thanks in anticipation
Hi. It's the upload speed that really effects gaming. With DSL you should be getting approximately 256 upload and that will be fine. A lot of the guys here just have a ADSL 512 connection and host many games fine. Have a look on http://www.adslguide.org.uk/ to compare companies speeds, reliability and customer service, rather than just choosing BT. I am with Eclipse and they seem to be near the top of the speed charts each month. Zen also seem to good.
The problems that arise are that upload speeds with connections are rarely as quick as download speeds. My NTL connection, for example, has 600k download and 150k upload - not good!
According to BT their 'basic' package, the £19.99 one does not support gaming, i have spoken to them and could not find anyone who could tell me why!. It says it on their website, and under the benefits etc it says that gaming and using more than one computer are not supported, but other than those two features it is the same as their £27 package, anyone know if this is true, or do you have it and use it for Xbox live etc.
BT are feeding drivel as usual. I'd be inclined to tell you not to use them, and go for someone like Nildram or Pipex instead.
Ok, having read the information they give, these are the issues : The modem that comes with the basic pack gives a USB network connection - to share this with another computer, or an XBox, requires a bit of fiddling. It's not impossible, as they state - it's just awkward. It also gives you a (paltry) 1Gb allowance a month. This might not be a problem for you, but bear in mind that it isn't nearly as much as it sounds Check out www.nildram.co.uk and www.pipex.co.uk - if you can get BT Broadband, you should be able to get it from these two as well
A USB modem and 1 gig cap are pretty big problems. I also hear that BT dsl has compatibility problems with some ADSL modems, so you might struggle to upgrade to a 'proper' modem. Just re-read your post, and 1 gig per MONTH?? Are you sure? That's virtually nothing at all, and you'll almost certainly exceed that if you do much gaming. Also, if you had a router it would be always on, and would be receiving all kinds of traffic which is basically the Internet background noise - pings and other random traffic that would eat into that feeble 1 gig per month. Pipex have a good reputation, and I think their standard service is a similar price to BT without the stupid restrictions. 512 download and 256 upload is plenty for Live
I believe that it says no online gaming support, this could mean they would not support queries about it. However, there is a 1Gb cap, this would be extremely limiting for online games playing. Say you needed to stream around 64kps, that equals downloading around 30Megabytes per hour. So you would be able to squeeze about 33 hours of gaming in a month. Not sure if the cap includes upload in which case you can just about manage 20hours of gaming This might be adequate, but I highly doubt it, especially as many games are starting to require higher bandwidth.
can recommend pipex mate works for their technical departmant. they dont cap your monthly limit and dont bloke any ports. also good speeds and prices. just get their 512 pachange and a decent router. Buy something like a netgear or linksys router stay away from dlink or cheap no name rubbish.
Good point img. Having just decorated my living room I am looking towards a wireless ADSL modem/router as my PC is upstairs and my Xbox in the living room therefore i want to avoid wires and cables running through the house. Could any of you give me any good value recommendations? I have been looking at ebay and found some for sale for between £70 to £130 but I must admit to being wary about buying something like this without prior knowledge of a manufacturers reputation or the model's real world perfomance. So if anyone has a wireless set up or knows of someone who has and is happy with it could they let me know what they purchased?. Thanks again
I have a completely Netgear solution - 824 ADSL modem/router/wireless access point, MA401 PC card, and an ME101 wireless bridge However, I did have problems using the bridge for wireless Xbox access, so I ended up connecting the xbox directly to the router via ethernet cable, and into the phone socket. Then wireless to my laptop, and wireless to my printer upstairs. Linksys or Dlink are also good brands, but I would recommend using the same company for all your bits if you are a beginner - their default settings are likely to be the same to get you up and running quickly. Oh, and I'd go for wireless 'g' now. Prices aren't any higher, but speeds and range are better (and more future proofed)
I got a free wirless router from work, its a generic one sent to our company as a sample so we could rebrand them and sell them. Does the job perfectly, get good connections, full bandwidth - no need to go overboard on the cost.
