I have some old MiniDV tapes that I want to look at and convert to my PC, but my old Cam isnt working any more.
I've seen some decks that I can buy to connect to my PC, but they look rather expensive, so I thought of buying a 2nd hand cam from ebay or something, just to rip them with.
I dont need the cam for using more than just to get the tapes ripped.
So, is it important to get a 'good' cam or is the cost/quality more for the lens etc, and can I just buy any old cam to do the job?
Any suggestions on a cam?
My PC has USB and also a 1394 port (the 6-circuit socket), or do I need some other input card?
Also, any suggestions on how / software to use to rip them, once connected?
I'm using WinXP, but soon upgrading to Win7. I have a decent computer, Core I7, SSD lots of disk etc.
Any help would be appreciated, thanks.
