MiniDisc Recording Advice
Discussion in 'Hi-Fi Stereo Systems & Separates' started by bigsby, Oct 8, 2004.
  1. bigsby
    bigsby
    Apr 14, 2004
    268
    +9
    Picked up a new Sony NetMD in an Argos sale a couple of months ago as a replacement for my ancient portable from around 97.
    Whereas my old machine had a direct mic input for recording from a (passive) microphone does not. I assumed that just plugging into the line input would work but it doesn't. Can anyone tell me how to get around this? Would buying some sort of active microphone work? Can anyone recommend a good active mic of the clip on variety so that I can continue to bootleg concerts? ;)
  2. bobbypunk
    bobbypunk
    No way round it some models have mic in some don't.
    Using the new models as examples the MZNH600 doesn't but the MZNH700 does have a mic in.
  3. KevinP
    KevinP
    You can buy external microphone pre-amplifiers from some audio specialists (soundprofessionals.com, microphonemadness.com - please delete this mod if it contravenes any rules). A good, portable one would set you back a fair bit, though the quality should be much higher than from the built in Sony mic-inputs.
  4. bigsby
    bigsby
    Apr 14, 2004
    268
    +9
    Thanks for that. I haven't looked yet, but it may be cheaper to buy a new recorder.
    I assume that something like this wouldn't be any good:
    http://www.dabs.com/uk/channels/hom...andmicrophones/productView.htm?quicklinx=123W
    It says it features "plug in power" operation, but I don't know what that means!
  5. KevinP
    KevinP
    No, unfortunately "Plug-in Power" operation means that the recording device must have a built in power supply to the mic (ie. a mic pre-amp/mic jack). There are self-powered mics available, but again they're not cheap. Electret mics use small button batteries, but don't provide plug in (line-level) power.....
