Question Mini system upgrade option
Muzzy5
Hi all. I am looking for suggestions for a receiver to replace a cheap JVC mini system. My listening is split between DAB, Bluetooth and internet radio as well as vinyl from an AT-LP120. CD is not that important to me but I’d definitely like the option to add a CD separate at a later time. Subwoofer our would also be a bonus. Speakers are Mission LX2s.
Would be great to know if anyone has any suggestions for something in the £200-£400 range. Cheers :)
Hixs
Used Yamaha RN803? It has everything you want.
Given they're 500ish new in the UK, finding one used for 400 shouldn't be that difficult.
RBZ5416
If you don't need to fill a huge space I'd see if you can get a listen to a Marantz MCR 611. Richer Sounds stock them together with your speakers so a demo shouldn't be too hard to arrange.
Muzzy5
Hi thanks for the suggestion. Unfortunately I’m quite far from a Richer Sounds so demo isn’t really an option. The Marantz looks good but the limited input options is making me want to pay a bit more for something else. I’ve pretty much decided it’s going to be either the RN803 or TX-8250 just can’t decide between them! Cheers.
Hixs
I'd go for the Yamaha myself. It's room correction software is a big bonus.
SVS Prime Wireless Pro Powered Speakers - Review Coming Soon
