Mini iPod problem
Discussion in 'Headphones, Earphones & Portable Music' started by Jedwards, Feb 8, 2005.
Tags:
  1. Jedwards
    Jedwards
    Jan 31, 2005
    44
    My mini iPod seems to be shutting down for long periods of time for no apparent reason. Whenever I turn it off, it won't turn back on regardless of the battery strength. It seems to re-boot itself after a few hours but until this happens I am unable to do anything with it. It also means that I am unable to connect it up to itunes.
    Does anyone know what may be causing this, or how this is resolved?
    Thanks!
  2. mick's cat
    mick's cat
    Have you tried resetting it?
  3. Jedwards
    Jedwards
    Jan 31, 2005
    44
    No I haven't. Can you tell me how to do this?
  4. mick's cat
    mick's cat
    Reset for the iPod mini is done by pressing the Menu and Select buttons at the same time and holding for several seconds.
    If you still have problems, try the Apple support site:
    http://www.apple.com/uk/support/ipod/
    and follow the Solving Problems link. Keep us posted.
  5. Jedwards
    Jedwards
    Jan 31, 2005
    44
    Solved!
    Thanks ever so much for this, I appreciate your help!
  6. mick's cat
    mick's cat
    Great news. Glad to have been able to help.
