Mini DV tapes with Cassette Memory ??
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by norfy, Aug 18, 2003.
  1. norfy
    norfy
    Do these exist ? Are they worth the extra money ?
    Only after I bought my camcorder and tapes could I open the manual and read that they recommend using tapes with Cassette Memory... DOH !!!
  2. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    They do and are VERY expensive. I got some and they were almost twice the price of regular mini DV tapes. I think the memory allows you name the tape and do fast index searching of the tape. All I've done is name my tapes so far...
    Personally, I don't see any quality improvement over other tapes .
    The cynic in me wonders if this is just a marketing ploy to sell overpriced tapes????
    If you want to give them a try most Sony Centres should stock them.
    Owen
  3. norfy
    norfy
    Funny that, seeing as though it was a Sony manual that suggested I buy them ;)
    I think I'll stick to the usual ones, cheers for your help
  4. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    Yep I thought so too :D
    Anyone know if you can get decent wide angle / telephoto lenses which will fit these Sony camcorders at a good price? The Sony branded ones are silly money.
    Owen
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    owen,
    try www.keene.co.uk they have tele from £20 & wide from £50
    Is this what you call 'a good price'? :clown:
    Mark.
  6. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    cheers mark,
    Have you bought from them yourself? What's the quality of their lenses like?
    The local Sony centre was looking for €300 a piece for 2x wide angle and telephoto lenses!
    Owen
  7. Duster
    Duster
    Dec 4, 2002
    421
    UK
    If you use tapes with Cassette Memory, you can also get words and titles to come up on the TV screen, when you play back your tape.
    This only works if you dont use the DV out, IE use the S-video or AVI plug.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    owen,
    I have used keene on a few occasions and their service has always been very good. I have however never bought or used any of these lenses.
    These lenses are are not made by keene, but by makers such as Sigma & Hama. I have used their lenses in the past on SLR's and have found them to be of good quality.
    HTH,
    Mark.
  9. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    thanks for the advice mark
    Owen
