Mini DV - can't view footage from previous camcorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dood, Aug 24, 2004.
  1. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    I've just bought a Sony HC30E hoping that the image quality will be better than that of my old Canon MV 300.
    Yesterday I recorded a scene onto mini DV using the Canon. I then removed the tape and put it into the new Sony, then recorded the same scene to do a comparison. When rewinding the tape in the Sony, I was able to view what I had recorded with the Sony but everything previously recorded on the Canon did not show (blue screen). What could this be due to?
    I now need to check if the old footage will play back onto TV or get captured onto PC from the new Sony camcorder.
  2. Roy Mallard
    Roy Mallard
    Did you record on Long Play mode using the canon?.
    This can happen in long play but shouldn't happen in Standard Play.
    If it's any use a 4pin > 4pin firwire should let you dub from the Canon to the Sony regardless of it being standard or long play.
    The canon is getting on a bit now so this may be a good idea as a matter of course.
  3. Roy Mallard
    Roy Mallard
  4. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    I know that the recording on the sony was in SP. I'll have to check if the recording on the canon was LP. If the sony can't be used to capture the old tapes, I guess I'll have to use the canon to capture old footage before selling it. I don't have a 4pin to 4pin cable and can't get one in this country but hope to get one from abroad soon - will be useful for capturing onto my laptop too.
