Mini Bedroom Cinema
S
subaru6r4
Hi everyone,
I am trying to search for separates that will allow me to do the following,
*Watch TV with sourround sound (4 speakers)
*Listen to a hi fi system with the same 4 speakers
In other words can I run a wire from a TV into a hi fi system and use the hi fi's speakers ?
These are what I am currently looking at
Hi Fi http://www.argos.co.uk/webapp/wcs/s...atalogId=3151&productId=123733&clickfrom=name
TV http://www.argos.co.uk/webapp/wcs/s...talogId=3151&productId=119011&clickfrom=image
From the info from argos, I think the hi fi sends the video/audio (DVD) to the TV and also plays the audio on it's speakers. When I play normal TV how will I be able to get the TV's audio playing on the HI FI's speakers ?
Thanks alot, any help would be great.
MagicBoy
Established Member
Shouldn't this be in the Integrated Amplifiers & Receivers forum? Anyway ...
I don't think the items from Argos will do what you want - the website doesn't indicate if the hi-fi has additional analogue inputs or the tv has audio outputs. My gut instinct is neither will have. Also the hi-fi only seems to decode Dolby Digital - DTS is available by optical output (ie it won't decode it) and there is no mention of Dolby Pro-Logic which is required to get 5.1 sound from a stereo input.
As Toxicmango said, suggest a budget and we'll see what alternative suggestions we can come up with.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
