Quantcast
Mindows 2000 Log in
Bogside
Is there any way to disable the windows 2000 C/A/D log in screen.
I'm the only person who uses my PC so I don't believe that I actually need this security feature (though feel free to correct me if I'm wrong).
What I'm aiming for is for the PC to automatically go to my desktop when it boots up as the extra screen for log in seems an unnecessary step.
Mr.D
Yep its doableand its easy but I'm darned if I can remember where it is . ( I could probably find it if I had W2K sitting in front of me).
Just make sure your default login is administrator level ( anything less will just cause you hassle unless you are on a network with other users).
Bogside
Thank you very much. This has been annoying me for ages and I wish I'd asked the question sooner.
