Mimo and Tremo
Discussion in 'Home Cinema Speakers' started by willdonaldson, Jul 22, 2004.
  1. willdonaldson
    willdonaldson
    Just got a Loewe Mimo 28 with DD upgrade and Tremo speakers. My problem is this... When I go to set up the speakers via the TV I get the option to set up Concerto speakers or BOSE but not Tremo. If I use these then the volume is very loud and uncontrollable - the neighbours won't be too happy. I can use the 6 channel setup but its obviously not Dolby.
    What can I do to fix this?
  2. willdonaldson
    willdonaldson
    The answer is in the software built in to the Mimo. Needs to be 6.1 or higher to work the Tremo. Mine was 3.5, hence the problem. Now need an engineer to come out and fix it. Can't wait..........
