Milti-region hack for Sony DVP-CX985V
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by wydchr, Jun 7, 2005.
  1. wydchr
    wydchr
    Sep 8, 2004
    109
    West Yorkshire
    +4
    Anyone know of a hack for this muti-storage 400 disc DVD player Sony DVP-CX985V?
    Thanks in advance.
    Dave.
  2. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    No hack for Sony multichangers. And if this is the NTSC version, even if there was a multiregion mod, you still would not be able to play PAL discs, not because it isn`t multiregion, but because its NTSC only!
  3. wydchr
    wydchr
    Sep 8, 2004
    109
    West Yorkshire
    +4
    OK, thanks for that.... next question is, anyone know how to convert PAL DVDs to NTSC ??
    cheers,
    Dave.
  4. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    just to clarify this, even if you modify a s Sony NTSC playback only machine to multiregion, if you insert a PAL disc, the player will refuse to read it, saying "incompatible disc" or "this typoe of disc cannot be played".
    If you want to mod a machine to be "truly" all regions, you need a dual format PAL/NTSC model to start with(i.e European, Australian or Asian model).
    Hope that helps:)
  5. wydchr
    wydchr
    Sep 8, 2004
    109
    West Yorkshire
    +4
    Do you know of a multi-storage player that is dua NTSC/PAL fomat?
    I have already bought the Sony but maybe able to return it as I haven't opened the box yet.
    cheers,
    David.
  6. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    Sony have not made any in europe for a few years now, the last one they made was the DVP-CX860 (2002). The NTSC issue applies mainly to Sony and some Panasonics, other brands such as most JVC and Pioneer models are actually PAL/NTSC even when stated as NTSC only. Best way to check if a machine you have is PAL compatible is to make a pal test disc from this link.
    Pioneer made a multi-disc changer, although I don`t think they make it in the US any more, that being the DV-F727. There is no handset hack, but it can be modded via a firmware change. Other then this, thats about your lot really other then Sony:(
  7. wydchr
    wydchr
    Sep 8, 2004
    109
    West Yorkshire
    +4
    I needed the multi-disc changer for the USA although I'm a Brit. We have just bought a house in Florida and we intend to rent it out and I figured that if I had a multi-changer with on-screen menu facilitlies then I could lock the multi changer away in an owners closet and not worry that people might steal my DVS and we have a lot of PAL movies that we wanted to take over there.
    I wonder if there is some other method of providing the same sort of service but not a DVD player, something like DivX movies from some sort of server?? Any advice would be most welcome... I guess this thread is moving away from its original content and maybe I should start again in another section?
    cheers,
    Dave.
