Miller & Kreisel - CS-how high?
Discussion in 'Home Cinema Speakers' started by AngelEyes, Mar 10, 2006.
  1. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,635
    Hi Chaps,
    Just curious what height you recommend. They will be right behind the listening position (sofa), literally with the sofa almost touching them.
    Should I aim for a height just below the top of the sofa, above, or doesn't it matter?
    Thanks,
    Adam
  2. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    +1,635
    M&K Column Surrounds... sorry bit cryptic :oops:
    Cmon Recruit gimme the lowdown!
  3. recruit
    recruit
    :laugh:
    Adam - IMO the CS29's are about the right height and i know quite a few people with these and have been very happy with results, the C22's are more discreet and the CS35's will probably give better results but with the compromise of being seen due to there height and then the CS150's are for a dedicated room where it does not matter what they look like but performance is paramount...:)
