Mikomi 17" LCD from Argos - wall mountable?
Discussion in 'Home Cinema Buying & Building' started by Coolhand, Mar 17, 2005.
  1. Coolhand
    Coolhand
    Jan 17, 2002
    61
    +8
    Looks like a nice bargain for the kitchen , but doesn anyone know if it's wall mountable?
    Link
  2. jon2099
    jon2099
    Jun 4, 2003
    183
    Hampshire
    +4
    I had this for a day (found the picture too noisy, even from SCART RGB) and yes it is wall mountable. The stand has 4 screws which come off and you can fit a VESA-compatible wall mount. The internals are similar to the Toshiba 17WL46B as the manuals are almost identical; the Toshiba has a much better panel though.
