might get an xbox, few questions
Discussion in 'Xbox Forums' started by arnoldma, Jan 16, 2005.
  1. arnoldma
    arnoldma
    Sep 4, 2004
    64
    thinking of getting an xbox, and hooking it up to my 20" lcd mointor for my PC (as it has 4 AVs) i can just leave it connected on s-video and tab the monitor to s-video from DVI-D when i wanna play xbox...
    the only problem i got is what can i do about sound? i have a 5.1 connected to my PC, and it only has a AUX input left on the speaker's base... so how can i go about getting sound? thanks, bye.
  2. arnoldma
    arnoldma
    Sep 4, 2004
    64
  3. Bonesy
    Bonesy
    Feb 22, 2002
    1,160
    Wiltshire
    +28
    if it will accept an aux input, then with a suitable xbox adapter you can have optical digital out.
    Does your amp support optical in? and why is it on the speaker's base?
  4. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,450
    oop north.
    +3,022
    I'm not a techy person but you can get a cable that, as well as plugging into your xbox and monitor, has the red and white audio connections spurring out of it...stick these into the nearest stereo and voila!!!
  5. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    what ? it turns the audio French ??
    /coat
  6. arnoldma
    arnoldma
    Sep 4, 2004
    64
    lol geordie jester :D
    yeah all the plugs is on my speakers sub, because it's one of those cheap computer spakers set... and no i dont have optical digital in on it, i was htinking of getting one of those phono leads, and then get some spliters and split the input on the speakers sub, that way i can connect the xbobx to the front left and front right, while still using those r for the computer aswell.... only thin is i wont get the 5.1 sound for xbobx!
  7. Obuggrit
    Obuggrit
    Some amps require you to leave the rear ports alone when only using the front speaker ports - it'll make use of all the speakers then in 2.1 mode
