Might buy a projector. Help
Discussion in 'Projectors, Screens & Video Processors' started by Beany31, Jun 11, 2009.
  1. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    Hi guys. I am pondering on the idea of a projector but don't want to spend too much for one as I'm a student!
    I doubt I can get a 1080p one so I'd like to ask a few questions about a 720p one.
    Currently I have an 32" LCD to play movies on BluRay with the output of 720p or 1080i.
    If I bought a projector and outputted 720p would it look better on a projector or no? It would be good for it to be on a larger screen though.
    Also... I probably won't buy a screen as in the flat I'm moving to I can't put any fixtures on the walls or anything :( so what would it look like on a White window blind or a white painted wall? Cheers for any help.
  2. Big_Si_Owen
    Big_Si_Owen
    Sep 30, 2008
    1,214
    63
    Royston, Herts
    +239
    Take a look at my link in my sig. That's projected onto a cheap white roller blind. It'll be fine if you can't do any more at the mo!
    Is a bit of a stop gap until we have our extension built later in the year and get a proper BIIIIIIG screen when we move the living room! :)
  3. VKP
    VKP
    Jun 15, 2008
    56
    11
    no point geting a projector if ur room is small u wnt b able to get a good screen size
  4. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    The room isn't that small mate.
  5. VKP
    VKP
    Jun 15, 2008
    56
    11
  6. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    I will probably get one second hand as I'm a student :)
    Would 720p look good then? Because it looks good on my TV but I guess it would look the same, but bigger on the wall?
    For a cheap budget what would be best, DLP, LCD or D-ILA?
    I'd need a projector that can connect to my Xbox or Samsung HTz-310r surround sound.
  7. VKP
    VKP
    Jun 15, 2008
    56
    11
    AH problem m8 u wnt b able to use a hdmi cable if ur using xbox...cz u wnt b able to get no sound cz the optical is built in the rgb cable so u have to use rgb to get the sound..
  8. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    Hmm so I'd use my Xbox component cable to get 720p? Wouldn't the pic quality worsen?
  9. VKP
    VKP
    Jun 15, 2008
    56
    11
    sorry m8 but u wnt b able to 720p picture with rgb... u going to have to some modification to ur rgb cable if u want sound going thru to ur surround sound and have hdmi cable connected at same time
    here the link to do it
    Xbox 360 Premium - HDMI Cable / Digital Optical Adapter Hack
    i wouldnt recommend it!
  10. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    What about the BluRay player?
    HDMI to the Projector and Optical out to the Amp?
  11. VKP
    VKP
    Jun 15, 2008
    56
    11
    u would need a splitter for it
    XBOX >>> HDMI >>>>
    SPLITTER>>>>> PJ
    Blu Ray >>>HDMI >>>
    ebay has cheap splitter
  12. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    Could you link me? just so I know what I'm looking for :)
  13. VKP
    VKP
    Jun 15, 2008
    56
    11
  14. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    Well if I was using surround sound, the HDMI would go to the BluRay yes and the optical out from the Bluray would go to the amp I presume?
  15. VKP
    VKP
    Jun 15, 2008
    56
    11
    yes
  16. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    Thanks for your help mate. But what's better budget wise and quality wise. DLP, LCD or D-ILA?
  17. VKP
    VKP
    Jun 15, 2008
    56
    11
    LCD pj tech is good but not good picture wise (my opinon)
    DLP is good PJ, out puts good quality pictures (i got DLP pj)
    D-ILA - out of my price range!!im onli a student bruv lol but if u do thik of buying it, its £1000++++
  18. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    I'm a student too mate :D can I see your setup?
    Are there no budget 1080p projectors? I'd like to just maximise BluRay playback that's all.
  19. VKP
    VKP
    Jun 15, 2008
    56
    11
    1080p pj are expencive i thik they go for 500-600+ dont quote me on that tho
    im still in process of installing ma pj once its done i will be posting it
  20. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    Pm me when you do, you've been a great help mate. :)
    I will buy if in my new flat I have space.
  21. VKP
    VKP
    Jun 15, 2008
    56
    11
    will do bruv
    this is what i have soo far
    40inch samsung lcd tv
    5.1 surround sound
    xbox360
    about to buy ps3
    sky
    pj hd700x
    92inch screen
  22. Beany31
    Beany31
    Nov 23, 2008
    5,130
    Kent
    +582
    Sweet, mine is in my sig, and I have a Samsung HTz-310r surround sound system ready to be set up when I move, can't wait. :D (1st July)
  23. VKP
    VKP
    Jun 15, 2008
    56
    11
    PARTAYYY lol.....:thumbsup:...:smashin:
    i brought HT-TZ225R on tuesday, sound is clear as my windows lollll....
