We have a Miele G6065 SCVi XXL dishwasher that is 3-4 yrs old. It worked fine with no problems. It was removed in the middle of the first lockdown when we started to refit the kitchen and I have only just reconnected it. However it seems to struggle to fill with water and generates an F12 or F13 fault code that indicates a supply/pump fault.
It sounds as if it is filling a bit, then stopping, then filling a bit more. There is no problem with the supply because I have connected a washing machine there that worked fine. Could be an air block somewhere or a maybe faulty valve. It is one of these where there is a valve connected directly to the tap.
Is there anything perhaps that I should look at before calling someone out?
