Midrange frequency range
Discussion in 'Home Cinema Speakers' started by braidkid, Mar 16, 2005.
  1. braidkid
    braidkid
    Hello,
    My understanding is that a lot of home theatre speakers are critized for not delivering enough mid range. My satellite speakers, for example, have a freq range of 120Hz-20kHz. If I were to get speakers with a range of 80Hz-20kHz would that be enough of a difference to bring out more midrange? I guess my real question is does anyone know exactly what frequencies the midrange fall into? Should I look for speakers that go down to 60Hz instead?
  2. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    As I understand it (and I'm usually wrong!) it's satellite speakers generally that lack midrange, this was borne out by all the satellites I listened to.
    The drivers and cabinets just aren't big enough to move enough air - so while they can respond down to <100Hz, the response isn't very large. The sub takes care of frequencies below where the sats stop, but above the sub crossover point satellites just don't produce much volume until you get up into 'high' frequencies.
    If you want a 'bigger' sound, i.e. better midrange response look into replacing the centre and fronts with fullsize bookshelves or floorstanders.
    What speakers do you have and what's your budget?
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Midrange frequencies are around 500Hz-5Khz.
  4. howesey
    howesey
    Remids me of this for some reason:
    http://www.intellexual.net/bose.html
    and
    http://home.earthlink.net/~busenitz/bs.html
    Guessing as the Bose systems use small speakers as well.
  5. braidkid
    braidkid
    I have the Infinity TSS-750 system. Unfortunately the satellites only go down to 120Hz and the sub down to 34Hz. I guess educating yourself after the purchase isn't the best idea....ignorance is bliss. :) Anyway, I'm contimplating getting the M&K 750THX package but not sure if it'll be a drastic improvement over what I have now.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    I've never heard the Infinity speakers so can't comment but let your ears be your only guide and give the M&K's a good long demo of mixed materials and see what you think.
  7. howesey
    howesey
    You have never heard of Infinity? Oh my.
    Also, have a look at the Infinity Oreus 5.1 system. Very good system for the money.
  8. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Braidkid, bear in mind you don't have to replace the whole package! If you replace just the fronts and centre with more suitable speakers you'll save some cash, use the remaining sats as part of a 7.1 system and upgrade incrementally.
  9. braidkid
    braidkid
    Mango, that is a good idea, however I'm afraid of mixed speakers because of bad timbre matching.
  10. Roohster
    Roohster
    Jul 1, 2004
    4,709
    7
    Derbyshire
    +5,798
    Some purists might say otherwise, but while it is important to have timbre matching for the front three, it's less important for the rears.
  11. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    True, it's more important if you're going to listen to multi-channel music. Still a reasonable upgrade path though.
  12. AverageJoe
    AverageJoe
    Jan 9, 2005
    28
    I have just got MA Radius R90 fronts/rears and R180 centre with a Quad-L sub. Have to agree that mid lacks presence. Other half said she wanted discrete speakers but I keep thinking was it a compromise too far? If only I can find a way of getting some 30cm fronts tucked behind the AV cabinet so she can't see them....
