Mid-range to high-end DVD player recommendations
Discussion in 'Blu-ray & DVD Players & Recorders' started by MrNPG, Aug 25, 2005.
  1. MrNPG
    MrNPG
    Apr 13, 2005
    714
    Poole, Dorset
    +44
    Hi folks,
    I'm thinking about buying a better DVD player, budget of upto around £500.00.
    Which players do you recommend?
    I'm quite keen on the Denon 2910. A good choice? Or could I do better for the money?
    I'm not worried about players that have lots of additional "features" and "trick play" functions, all I want is a player that has excellent picture and sound quality. It will be connected to my plasma via Component.
    Cheers.
  2. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    If I had the dosh I would buy the Denon in a minute - I even have the firmware update disc in my collection for making it multi-region!
    Apart from that you can listen too true SACD from its 5.1 output and it does digital 96/24 sound.
    Has won many awards since its release and still keeps winning them!
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I would look a bit futher than the 2910 but £500 is a difficult price it falls between two stalls of say a Panyy97 (£150 recommended and better picture!) and the Arcams (£1k rec), you might get new features but is that what you are after, I get the impression you want the basics done correctly? Top flight component engineering is what to look for here, the Pioneer 868 might be worth a look.
  4. MrNPG
    MrNPG
    Apr 13, 2005
    714
    Poole, Dorset
    +44
    Hi Nic, yes the £500.00 price range is a bit tricky I know.
    You are correct, I just want a good quality player that gives an excellent picture quality. Pioneers are good but I was put off them recently when I had a DV-380 which was very noisy in operation (I could here it "buzzing" whilst watching movies, it was very irritating and I could not live with it) not sure whether the more expensive Pioneers suffer from this? I like my DVD players to be silent whilst playing a disc.
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    It is not perfect, nothing is, but it is one of the most dependable players I have ever player with. I think the componet outputs on the top Tosh good and Arcams are excellent, however most things at £500 might be a little too compromise to show any great jump in quality. What about a second hand Arcam?
    Nice LD :)
  6. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I am reasonably happy with my 2910. It did fall into what I considered an affordable bracket while the 3910 was 'too much' in my opinion. In hindsight the extra cash might have been worth spending because the 3910 is a more complete solution when mated with a 3805 or above (the amp I have). However £300 rrp difference is a lot to swallow when my 3 previous DVD players did not cost that each. However, while they excelled in one or two places, none had the spread of ability the Denon does.
  7. MrNPG
    MrNPG
    Apr 13, 2005
    714
    Poole, Dorset
    +44
    Hi Cable Monkey. So as far a picture quality is concerned, is the 2910 a good performer? What connection do you use?
    Is the 2910 noisy in operation? Is it audible whilst watching a movie, during quiet sequences?
  8. neil e normal
    neil e normal
    Aug 25, 2005
    11
    pioneer dv 868avi (great player) silent operation aswell
  9. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    2900 is a great machine and better value than the 2910/3910 (if you don't need hi-def). Can be had for £400.
    DT
  10. neil e normal
    neil e normal
    Aug 25, 2005
    11
    bought my 868avi for £300 second hand, it is as new
  11. MrNPG
    MrNPG
    Apr 13, 2005
    714
    Poole, Dorset
    +44
    The Pioneer 868 is definately another contender. Is the 868 MUCH better than the cheaper 668? Worth the extra few hundred quid?
