Mid Performance PC -Recommendations Please
Discussion in 'Desktop & Laptop Computers Forum' started by vex, Jun 14, 2005.
  1. vex
    vex
    Mar 8, 2005
    2,888
    103
    London, Home Counties & North West
    +261
    It is time for a new PC. :clap:
    I have an acceptable LCD Screen and will just need a desk top with a new keyboard, mouse etc.
    I want to be able to edit the DV from our new camcorder. Other desires are.
    512 or 1G Memory
    100Gb + Hard Drive
    Network Connection
    Lots of USB ports
    Have not looked at pc's or specs for about 3 years what else should I consider and where should I go. :lease:
    If budget allows, I might even want to add a couple of tv / freeview cards for future storage/distribtution down to the lounge.
  2. marky_h
    marky_h
    Dec 19, 2002
    355
    Hampshire, UK
    +23
    I presume the DV cam connects via Firewire? If so, it makes sense to choose a suitably-equipped motherboard. I've built quite a few MSI and Asus-based systems (as regular PC's and media centres) and they are pretty steady, so I'd recommend either of those, or Gigabyte, as a mobo manufacturer.
    A custom-built system with a gig of RAM, 120 GB HDD, DVD Writer and an AMD 3000+ processor, plus a reasonable graphics card and case would leave you some change from £400.
  3. Maff et1
    Maff et1
    I believe media transcoding and encoding is one of the few things that still seems to work better on Intel processors.
