Question Microsevers and 4k
Discussion in 'Networking & NAS' started by tazg101, Dec 24, 2016.
  1. tazg101
    tazg101
    Dec 17, 2008
    1,059
    63
    +113
    I love my hp n4l but with 4K videos now available it may have come to an end off its lifespan.
    What's the best step up to stream 4K rips to my nvidia shield boxes?
  2. mickevh
    mickevh
    Apr 30, 2007
    7,178
    West London
    +1,716
    What makes you think that - perhaps you could expand on your thought process a little..?
    File servers don't "care" about the content of the files they contain and serve out. All that really matters is whether they can retrieve and present that data at a fast enough rate to "keep up" with the playback requirements. If the typical bit rate of a 4K video is (say) 30-50mbps, I'd be surprised if even ten year old hardware struggled. If you have Gigabit network it should easily cope, though 100mbps might be more of a constraint - especially if you want to sustain multiple streams (I'd forget about using Wi-Fi.) If you're thinking about storage, then replacing HDD's with bigger ones isn't usually too dramatic.
  3. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,277
    +1,258
    I agree with mickevh, it should be fine, if you are seeing an issue then that needs to be explored first
  4. tazg101
    tazg101
    Dec 17, 2008
    1,059
    63
    +113
    The issue I have is occasional buffering. I am running cat5e cabling. Does this need to be cat 6?
  5. Sloppy Bob
    Sloppy Bob
    Jul 6, 2009
    3,916
    +3,043
    As per michevh's post
    No but are your server, router or any switches you have in your network 100Mbit as opposed to Gigabit?
    I was having issues with 4K video and the reason was I had a 100Mbit switch. Swapped it for a Gbit one and all the buffering was gone.
  6. tazg101
    tazg101
    Dec 17, 2008
    1,059
    63
    +113
    Yeah. I have netgear GS116UK switch. Only one switch in the whole network.
  7. Sloppy Bob
    Sloppy Bob
    Jul 6, 2009
    3,916
    +3,043
    Yes, but what is the microserver and router?
  8. tazg101
    tazg101
    Dec 17, 2008
    1,059
    63
    +113
    Server is hp n42l micro server with a sky router.
  9. Sloppy Bob
    Sloppy Bob
    Jul 6, 2009
    3,916
    +3,043
    And........
    Do they have gigabit connections on them.
    If they don't, it's a bottleneck and having a gigabit switch will make no difference as the max throughput is 100 Mbit.
  10. tazg101
    tazg101
    Dec 17, 2008
    1,059
    63
    +113
    Yes they all do.
  11. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,651
    Im running a hp n40l microserver, its fine for all content.
    The only thing it wont do is trancode, it doesnt have the power for that, but as the shield can play everything natively, you dont need to transcode.
  12. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,277
    +1,258
    If the gigabit network isn't the issue then it could be the hard drive, os or configuration of shared drives.
    How do you have that setup?
    Have you confirmed you have the right drivers for the network card and that its actually operating at one gigabit.
    Does it always buffer at same place or random?
  13. DeepDiver
    DeepDiver
    Dec 24, 2007
    832
    43
    Stanley, Co. Durham
    +131
    Unless you have the sky q hub your sky router will only be 100Mbit. Reckon his server is HP N40l from his typos which has 1Gbit
  14. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,277
    +1,258
    Yes but he he has a gs116 which is gigabit and unless the micro server isn't plugged into this and is plugged into the router then it is on a gigabit network.
    I have seen a few issues where drivers though have either been generic our had issues and the correct driver has sorted.
  15. DeepDiver
    DeepDiver
    Dec 24, 2007
    832
    43
    Stanley, Co. Durham
    +131
    Exactly what I mean. He has not said exactly how it is setup? Only what he is using.
  16. tazg101
    tazg101
    Dec 17, 2008
    1,059
    63
    +113
    Hi.
    I have sky router which supplies the internet but all connections are going to my netgear switch (my house has network sockets ), I never use wifi for streaming.
    I have ordered one off the below for my microserver after further reading the socket in the server is limited to 100 mbit?
    Intel EXPI9301CTBLK PRO1000 Network Card CT PCIex https://www.amazon.co.uk/dp/B001CY0P7G/ref=cm_sw_r_cp_api_1wLyybXM4Q6QR
  17. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,277
    +1,258
    No on all the micro servers it's a gigabit network card, so whatever you have been told is wrong. However even on Windows os sometimes an incorrect driver can be used which operates at a slower speed. You must get the right and preferably latest driver for your os. Imo you are not solving the problem by buying the Intel network card.
  18. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,277
    +1,258
    Check in the network properties to see what it's connected at
  19. tazg101
    tazg101
    Dec 17, 2008
    1,059
    63
    +113
    Ok. In properties it says I'm connected at 1.0gbps
