Microphone recommendations for Sub BFD calibration with John Mulchay Room Wizard ?
Discussion in 'Subwoofers' started by Mark Grant, Sep 10, 2005.
  1. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    Planning on some BFD subwoofer calibration using room wizard and a BFD (Behringer DSP1124P for those that dont know what a BFD is)
    Will be using an M-audio Firewire 410 soundcard , as this has midi to control the BFD, a decent mike input (that supports phantom power) , high quality line level outputs, and firewire so can be used with a laptop easily.
    Problem is I dont have a microphone, so can anyone suggest a good quality microphone with suitable frequency response ( good low response needed) that does not cost a fortune ?
    Any links to suppliers appreciated.
    Thanks,
    Mark.
  2. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    The Behringer ECM8000 is a mic that is often recommended for low cost measurements. It is phantom powered, but in the professional sense. I think the M-audio cards phantom power is for electret capsules, i.e. low voltage unbalanced, rather than the 48v balanced that the Behringer needs.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I use that one.
  4. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    +171
    Thanks for the advice :)
    Behringer ECM8000 it is then, only about £30 + delivery :)
    Mark.
  5. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,092
    Detached from reality
    +1,451
    My laptop doesn't have a midi port :(
    Is there any other way to control the BFD? Some sort of USB - midi converter or would i have to purchase a seperate external sound card :( (more money)
  6. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    +171
  7. binbag
    binbag
    Jun 16, 2004
    1,694
    +81
    Can anybody recommend an inexpensive soundcard that will be suitable for using Room Wizard with a SPL meter; my old soundblaster doesn't appear to have enough connectivity.
