Microphone input on sony amp
Discussion in 'AV Receivers & Amplifiers' started by Peter O Sullivan, May 23, 2001.
Tags:
  1. Peter O Sullivan
    Peter O Sullivan
    I am having a party in a few weeks and wanted a karaoke. I am just wondering is there anyway that I can plug in a microphone into my Sony 830. I was thinking of using the 5.1 channel inputs, but leaving out the centre as the microphone channel. The pioneer 626dvd can decode the other channels if need be (i can say theres no centre hooked up).
    I got a connection today to hook up a mic of a computer to it but no luck. I plugged it into the centre input.
    Is there any other cheap way of doing this?
  2. Guest
    Are You Sure????!!!!!
    Amused
    SteveEX
  3. Guest
    For the 1 in 100 chance you are being serious:
    Karaoke : Sony 830 : Blown up speakers!
    Still Laughing
    SteveEX
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You need to get a microphone pre-amplifier if there is no dedicated mic input (which I doubt), then it could work.
    Seen a few DVD players with Karaoke function, perhaps you want to consider buying one next time ...
    I better not give my opinion to KO now ... :D
  5. Guest
    And if you connect any old tape deck to the dvd players SVID out socket you can record the whole evenings proceedings at 24Bit,96Khz resolution in true 11:1:4
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Really? I gotta try this ....
