microphone input help!
Discussion in 'AV Receivers & Amplifiers' started by Jroz, Mar 21, 2006.
  1. Jroz
    Jroz
    Mar 18, 2005
    35
    Hey guys..i have a sony reciever and i basically wanna add a microphone to the system so i can stay stuff while music is playing..havent been able to figure it out..theres a phono port but it doesnt work when i plug a microphone into it..i tihnk its for headphones..how can i add a mic to this setup....what do i need
    thanks
    Jason
  2. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    You need a mic pre-amp, such as this one. It'll be mono though, so you'll need a 1xmono jack to 2xPhono to get the sound out to both speakers.
    Search ebay for used examples, you might even find a small mixing desk, with stereo outs, like this which has onboard effects (reverb, delay etc..) to make your voice sound all wacky...........
    D.
  3. Jroz
    Jroz
    Mar 18, 2005
    35
  4. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    If you're in the US, then they should be fine, although the 1st one is a bit OTT.
    D.
