Micro System advice
Discussion in 'Hi-Fi Stereo Systems & Separates' started by RMCF, Jun 24, 2002.
  1. RMCF
    RMCF
    Aug 24, 2000
    7,567
    +785
    I am looking for a micro system for my kitchen and would appreciate any recommendations. It has to be relatively cheap and I only need a CD/tuner system - forget about the tape deck. As I have a full separates system in a dedicated music room I only want a small system. Nothing too expensive please.
  2. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I would go for the Denon D30 micro system - looks and sounds good
  3. Mikef
    Mikef
    Jun 21, 2002
    169
    16
    Another vote for the Denon, you should be able to pick it up online for £250 with speakers (and I'm sure I've seen it in Currys for a similar price).
    I'm also hunting for a kitchen system, though I'm trying to find something with smaller/more discrete speakers. Currys online had the Sony CMTC5 system (inc minidisc) for £250, but have now sold out.
    mikef
