Micro speakers
PBergin
I am currently using a set of Monitor Audio Bronze B1 book shelf speakers
for L&R speakers in my 6.1 setup but it looks like I might have to
find some smaller speakers and fit them into the corner by the
ceiling. So far I have narrowed it down to
Mordaunt Short Genie
Keff 2005
Morel Nova & Evit
canton CD10
What is your opinion on the above? are there any others I should consider?
I am in Dublin and there isnt a good shop which stocks all the above so it is not going to be possible to test them.
Will I loose much clarity by fitting the speakers so high?
Just in case you need to know, my systems is Marantz sr4300, Mordon
Short diPolar rears and a Monitor ASW sub.
Regards
Paul
A
arielshiran
If they are not too big for you, they may be better than all you mentioned and cheaper. Go to demo them.
PBergin
ahhh another set of speakers to consider!!!!!!!
I presume you were talking about the satelite speakers, I will also use these speakers for music, I presume you would still recommend them?
A
arielshiran
demo them. They are great for both music and home theater uses and I think that in their price they have no competition.
Other sets you might want to check which are full sets (including 5 satellites and a subwoofer) and are great value for money are Canadian:
Mirage Nanosat (omnipolar satellites).
Athena Micra (A great sound at a bargain).
Check these out.
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
