Micro atx motherboard
Discussion in 'Computer Components' started by bob1, Sep 1, 2007.
  1. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    Hello, i'm looking for a micro atx motherboard so i can get my pc into a smaller case.
    I have a xp2600 cpu and pc400 ddr and would like to use these ,can anyone recommend a mother board to suit and the best place to buy.
    Thanks.
  2. Grimley
    Grimley
    Sep 19, 2003
    1,013
    4
    2
    67
    Deepest, Darkest Essex, so BEWARE!
    +184
  3. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    Thanks for the reply, ive gone and bought a motherboard and cpu package ,the board you pointed too came up a few times but i wasn't sure if my memory would go with it ,just got to find a smaller case now.
  4. Grimley
    Grimley
    Sep 19, 2003
    1,013
    4
    2
    67
    +184
    AFAIK the Ram would be clocked at the default speed of the Motherboard (333Mhz) it should be OK to use Though I'd consult the motherboard manual 1st
    (I've checked it online & it says nothing about it - perhaps others here can verify what I said)
    http://download.asrock.com/manual/K7S41GX.pdf
  5. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    It wasn't the board i bought but thanks for your efforts ,this is the board i got HERE with an amd64 3400+.
