Mico Clasica 20 Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by deg, Sep 12, 2003.
  1. deg
    deg
    Can anyone confirm if the Mico Clasica 20 plays VCD's, SVCD's, DVD-r etc. All the reviews i read before buying one said it does. Unfortunatley mine doesn't seem to like my SVCD holiday video or my mates DVD-R's. Is it just my machine or has anyone else experienced such a problem
  2. Nimrod666
    Nimrod666
    I know that this is not a good fix but it works, put the VCD in the tray, when you see 'load' keep pressing the number '1' on the remote until you see 'vcd' displayed then play. I believe that there is a firmware upgrade available but all mails I send to Mico are bounced so have no idea how to get hold of it. Will post again if I get any more info.
  3. Nimrod666
    Nimrod666
    Re the above I have the upgrade from Mico, mail me for more info
