Mico 3000 dvd Player - Unable to play dvd copies..Grrr
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by nico_2t, Jul 8, 2005.
  1. nico_2t
    nico_2t
    Hey all... :hiya:
    hope somone can help...dvd player wont play dvd copies nor vcd (managed to get a hack for the vcd and it now plays fantastically) however, have read that there is a hack for the dvd side of it....anyone have any hacks for this???? :lease:
    Any help would be gratefully received
  2. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,174
    63
    Location location location
    +93
    Sorry you cannot do anything about this. You cannot add disc compatability to a machine that does not already support certain types of media, as the reason the discs you want to read canot be read are due to the type of laser assembly used. The only option is to make sure a machine supports the types of media you want to play in the first place (other then DVD and CD discs) before purchase.
