Mf A3.2cd
Discussion in 'Hi-Fi Stereo Systems & Separates' started by kocl, Nov 5, 2003.
  1. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    Does the MF A3.2 CD decodes HDCD?
    Its a good player or should i buy a DAC.
  2. mjn
    mjn
    May 24, 2001
    22,123
    Herts, England
    +9,880
    no, it doesn't do HDCD as far as i can remember
  3. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    Is still a good choice?
    Or there are others within same budget, that are better.
  4. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    Is a good choice, or there are others within same budget, that are better.
  5. mjn
    mjn
    May 24, 2001
    22,123
    Herts, England
    +9,880
    well i use the a3.24 DAC which is great, and i believe the new a3.2 uses the same DAC now.....you'd have to check though.
  6. overkill
    overkill
    Nov 6, 2003
    11,842
    Murkeyside
    +1,205
    It's a nice machine but it has some stiff competition from the Meridian 507 and Naim CD5 around the grand mark. Also, slightly cheaper is the Marantz CD-17 or it's more expensive brother the KI SIG which are both good performers.
    In the end it's down to what you want from your music, and what you feel happy with after a demo. Personally, i would stretch for the Naim, but (and there's always a but!) it's not as well built, although still up to Naims high standards, as the MF and doesn't suit everybodys taste.
    Dem the A3.2 against the above models with disks you know well, and see what you're comfortable with.
    Hope that helps.
