Mering 2 partitions
Discussion in 'Computer Components' started by Spaced-Man, Jan 16, 2008.
  1. Spaced-Man
    Spaced-Man
    Feb 4, 2006
    132
    Hampton
    Is there a way to merge 2 partitions on a HDD without 3rd party software?
    I use Xp home edition and someone said I could do it in the administrative tools in the control panel.
    Is this possible?
    If so, how do I do it.
    Thanks.
  2. wormvortex
    wormvortex
    May 29, 2005
    5,758
    South of Heaven
    +442
    administrative tools then disk management :)
  3. Spaced-Man
    Spaced-Man
    Feb 4, 2006
    132
    Hampton
    Found it, what do I do now?
    If I right click on the partition I want to get rid of I get the option of "Delete Logical drive", is this correct?
    I'm not that computer savy so if you could explain it in idiots language that would be a great help.
  4. wormvortex
    wormvortex
    May 29, 2005
    5,758
    South of Heaven
    +442
    er assuming one partition is empty you simply delete the partition then clicking on the other partition select extend partition and follow the instructions. Not sure if it will work if you have data on both partitions and wanted to merge them together.
  5. Spaced-Man
    Spaced-Man
    Feb 4, 2006
    132
    Hampton
    When I click on the partition I want to extend I can't see anything that says "extend".
    Does it matter if the partition I want to extend is called "system"?
  6. Old_Biker_John
    Old_Biker_John
    Mar 23, 2008
    168
    Exeter, Devon
    +33
    Hi Spaced-Man,
    To find info. about extending partitions in XP, try opening the 'Help' screen from the 'start' button and enter diskpart in the search box and press 'Enter'.
    You should find some explanatory notes about how to make the changes that you want.
    John.
  7. mjn
    mjn
    May 24, 2001
    24,104
    Herts, England
    +12,744
    Don't forget, removing partitons will delete any data on them.
    My advice would be to backup the data, delete both partitons, and create a new one.
  8. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    Pretty sure to do what you're asking you need third party software, such as partition manager. Messing around with partitions with data on there is risky, as said it's safer to copy data to another HD, then re-partition the drive, then copy the data back.
