eddiewww
i recently bought a whole sytem from meridien and had had a problem from the out... i have had meridien down, the shop director was even here today to try and sort out my problem... i wondered if anybody else had a similar problem.
when i switch between DSP modes i hear a distinct "crack" coming from some (not always the same and sometimes only one) of the speakers. i also hear it when i am not switching..ie listening on any of the inputs... it is irregular and not just my "looking out" for it. i thought i must be imagining it when i first heard it ! it also makes a similar but not the same noise when i put it into standby ... i have it hooked into a panasonic plasma and have heard that the high rfi on them can sometimes affect remotes and tried listening to the system with it unplugged and still hear the noise.
the shop are taking it back next week and trying it in there dem room to see if the "environment" is the cause .... but since the envirnment doesn't change when i change DSP modes i cant see that being the cause... they have said they will swap out whatever is the cause, upto and including the whole system .. so i know it will all be OK in the end .. but if it is something simple that somebody has experienced and can be done now.. then i want to do that ..
so... anybody out there had the same ??
my system is:
598 dvd audio player (progresive with MHR)
568.2 processor
5 X DSP33 (digital)
1 X D1500 sub (digital)
my system is:
568.2 processor
5 X DSP33 (digital)
