Meridian G-series remote
Discussion in 'Home Cinema Control & Remote Controls' started by VirusKiller, Sep 20, 2003.
  1. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    Does anyone know when the new Meridian G-series remote will be available?
    Looks great for £85.
  2. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    Done some digging of my own. According to local Meridian dealer, the first G series products will be arriving mid-Octoberish, but they have no idea which ones...
    Still, that's more information than on M's website...
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    the americans report that the whole range should be available early october
    Ad
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    any updates?
    ad
  5. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    Got one a week ago. Very stylish.
    Not sure that the 3rd party codes database is that great really and have been programming everything manually the way I want it.
    Backlighting is cool, but I've noticed a low level high-pitched whine coming from the unit when the backlight is on.
    However, for £85, the "one doofer to rule them all" is looking pretty good!
    Oh, and the ability to change around the source buttons is really useful - Meridian supplies lots of alternatives too (including blanks).
    Joel
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    So it programs easily enough and had a good range?
    ad
  7. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    Programming is easy. Can't be definitive about the range as I'm only 7 feet from all my kit, but it does seem to be pretty good (i.e. angle held doesn't make a difference).
    Oh. The first three Meridian sources and corresponding key mappings can't be re-programmed (RTFM). Was doing my head in for ages!
    Cheers,
    Joel
  8. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    thanks, im defineitely going to consider it...... i like having hard buttons and i dont really want anything exotic anyhow...... does it have an arrow pad of any sort? Like left right up and down?
    ad
  9. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    Yep.
    Have you seen this?
    Cheers,
    Joel
    PS I think the feel of the older MSR keys is much better. Just thought you should know.
  10. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Thanks i hadnt seen that. Looks pretty good to me..... just need to be able to change one of the source keys to be 'pc' :D
    did you just get it from your local dealeR?
    ad
  11. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    How about "Game"?! It's there by default!
  12. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    that would do the charm.... sounds like i know a pressie for xmas!
    ad
  13. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    What. To go along with your Z2 when it finally arrives :D
  14. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    and a whole load more! Unfortunately a course means that it will be the 11th until i see it :(
    ad
