hodg100
Outstanding Member
- Joined
- Aug 8, 2005
- Messages
- 14,220
- Reaction score
- 4,522
- Points
- 6,489
Following on the successful introduction of DSP3200 Meridian are to launch the DSP3300 useing similar electronics and drive unit technology, but housed in a more conventional cabinet design, adding a Digital Active Loudspeaker to the Meridian range that they say is perfectly suited to use as a centre channel in a range of Meridian Digital Theatre installations.
The DSP3300 is a two-way digital active loudspeaker that can be used either as a centre channel loudspeaker, for main left and right channels, or surround channels. The design of DSP3300 is based around twin 165mm bass drivers and also uses the same wide-range drive unit as was selected for the DSP3200. Both driver types are built around extremely stiff die-cast aluminium chassis and use efficient neodymium magnetic motors.
Cabinet construction follows a philosophy that is consistent across Meridians complete range of loudspeakers. The DSP3300 enclosure is constructed using materials that hopefully ensure it is stiff and well damped. The wide-band driver is mounted in its own separately sealed enclosure within the main loudspeaker cabinet.
The fully-integrated DSP engine that forms the core of each DSP3300 is used to perform unique crossover functions as well as providing advanced bass protection and loudness controls. With SpeakerLink input and output connections plus a simple channel selector switch, the DSP3300 should be easy to connect and to set up.
DSP3300 is sold singularly, so that it can be specified as a centre channel, and is supplied with a moulded rubber allowing means of angling the loudspeaker so that it projects its sound towards the listening. The same mount can alternatively be used to cradle one of the curved ends of the loudspeaker should a particular installation require vertical orientation. The DSP3300 can also be installed on a König & Meyer 24471 or 24481 wall bracket.
Like the DSP3200, DSP3300 is offered with two high-gloss paint finishes; Traffic White (RAL 9016) and traditional high gloss black with a suggested retail of £ 2,250.00 inc VAT.
