Meridian 596 DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Del, May 4, 2001.
  1. Del
    Del
    Nov 15, 2000
    783
    Berkshire / Okayama
    +16
    Hi Y'all
    I'm considering upgrading from Pioneer 919 DVD/LD to the Meridian 596 DVD or if it comes out soon 598 DVD Audio. :)
    The question is, are there any 596 owners out there?
    What is your overall opinion and have you had the software modified to Multi-Regional?
    If so any problems re RCE ?
  2. whitecot
    whitecot
    Nov 4, 2000
    19
    Surrey, UK
    I was lucky enough to get the SCART version of the 596 about 4 weeks ago. Absolutely superb! Even made a Tartan DVD look good. No problems with R1 or R2. The player claims to be R1 so I don't expect any problems with RCE. I've been warned that there may be a problem with R2 branched discs although my dealer then seemed to think this was R2 RCE which as far as I am aware doesn't exist. The region free change was made by the dealer.
    I'm using the player with a Sony FS36 TV with RGB input. Screen format swiching works perfectly (unlike with my Pioneer 626). I expected the sound to be a bit better than the Pioneer but I was amazed by the improvement in the picture quality.
    As CD player it certainly surpases my Meridian 206.
    Expensive but well worth a demo.
  3. Del
    Del
    Nov 15, 2000
    783
    Berkshire / Okayama
    +16
    Ta Whitecoat
    I needed a second opinion before forking some hard earned cash!!
    Q If you don't mind me asking, did you pay full retail?
    Del
  4. whitecot
    whitecot
    Nov 4, 2000
    19
    Surrey, UK
    Afraid so.
  5. Del
    Del
    Nov 15, 2000
    783
    Berkshire / Okayama
    +16
    Cheers :(
