Meridian 568 mkI...price check?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Smurfin, Aug 27, 2004.
  1. Smurfin
    Smurfin
    Aug 13, 2002
    21,427
    +4,373
    Could anyone advise what a Meridian 568 in mint condition would be worth. I've read some old threads and read that the upgrade to 568.2 spec is approx £700 ( :eek: )...anyone know if this is still the case?
    Where is the vanilla 568 (v 1.54) pitched in terms of other processors?
    Matt
  2. steve1056
    steve1056
    Apr 20, 2002
    384
    Reading
    +5
    Matt,
    I would guess about £1,500 for a 568.1 nowadays. I paid £1,800 for mine about 15 months ago, before 568.2's became more commonly available 2nd hand after the release of the G68. I would guess a 568.2 would probably now go for circa £2,000 (non-MM model).
    IMO, the 568.2 would probably be worthwhile, especially with the new software release (v2.5).
    BTW, the 568.1 was the best upgrade I've ever done. Having said that, I'm probably going to buy a G68 in the next 6-months or so, but that's because I need room correction, not because of any problems with the 568.
    Hope this helps.
    Cheers,
    Steve
