Greg Hook
Moderator & Reviewer
My boss has just got a Mercedes SL55 AMG, (the b'stard!) and the sat nav is giving us some problems. It is an 03 plate, so I'm guessing it has the original software in it for UK. Does anyone know if there is an updated CD for the sat nav? The current one is crap and for such an expensive car is ten times worse than my cheap tomtom one. We tried entering in a local town and it took us to somewhere completely different.
It would be good if there was an updated CD which updated the sat nav software to get it to work better.
Also, we are also after a Europe Map CD aswell if this is available?
If it helps, the sat nav software is called Mercedes Comand. (one m)
Greg
Greg
