Mercedes in car DVD/SatNav
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Churchclose, Jan 16, 2005.
  1. Churchclose
    Churchclose
    Does anyone know if there is a way to carryout any of the following mods, regarding my Merc E Class in car system, I have a COMAND APS inc radio, multi cd player Region 2 DVD player(only works below 5 mph) internal car phone also fitted
    DVD to work at any speed
    DVD to be region free
    Add rear screens
  2. Mondorich
    Mondorich
    Jan 2, 2005
    3
    Bedfordshire
    I've put a question on the MB Club Forums here
    Hope you get some feedback soon. Cheers. Mondorich.
  3. diesel_uk
    diesel_uk
    need to get the manual out and remove the "pulse" cable from the unit to the ECU/DASH.
    Again need to get the manual out so you can get to the "box" to add the screens to the video out/aux out,
  4. JiMbOb_74
    JiMbOb_74
    If your car has navigation, doing the above would render it usesless... :nono:
  5. Ayub
    Ayub
    Oct 15, 2003
    6,487
    Bradford
    +607
    no jimbo, Pulse does not disable . There are 23 sat out there it takes your position from these. However yes your distance to and from are greatly compromised.
  6. JiMbOb_74
    JiMbOb_74
    Sorry matey I fit satnavs for a living and without a speed pulse the system doesnt work at all. It doesnt rely on just the sats it uses the speed pulse and a gyroscope to 'follow' the maps....
    If anybody wants to try this and tell me I am wrong ... :nono:
  7. Ayub
    Ayub
    Oct 15, 2003
    6,487
    Bradford
    +607
    i wont argue with you Jim, I have ran a vdo without connecting the pulse and it worked fine. Was not 100% but was very good. In my case it worked. I cant speak for all, If you fit them then you will know more about them than me. Sorry for stepping on your toes. :oops:
  8. Churchclose
    Churchclose
    Im sorry guys but your words are just flying right over my head, Im guessing that the answer is noo to all my questions then?
    Thanks for all your advise and interest by the way
    :hiya:
  9. Churchclose
    Churchclose
    My car was delivered in January 04, I have no TV tuner so I guess that means no rear screens, but I would like to know how to disable the blank screen on the move
  10. thudspud
    thudspud
    Mar 28, 2002
    2,353
    Sheffield
    +127
    I 'think' if you can work out which wire is connected to your handbrake switch and earth it then it might let you use all of the features, I know this is the case on the Pioneer system and on the full screen toyota systems.
  11. Churchclose
    Churchclose
    Dont think that can work as the car is an automatic and I never tend to use the hand break, plus screen is active up to 5mph then turns off so the hand break is not realy anything to do with it on the Merc
  12. johnnykick
    johnnykick
    There is a way of doing it very simply.
    I know because I have done it tonight.
    I bought the instructions of a guy on e bay.
    It is a simple set of key instructions and you get into an advanced screen where you can turn on and off lots of options. One of them is 10km turn off
    I am not linked with this guy in any way only that it worked for me but cost me a £5 which is well worth it to me.
    good luck
  13. lazyjohn
    lazyjohn
    Mar 21, 2008
    As you install sat nav all day long could you help me with a problem
    I have retrofit a comand 2.0 in my clk and everything works fine, however i havent connected the speed pulse wire as i dont know what colour it is
    Can you help ??
    John
  14. mercedes_777
    mercedes_777
    Jul 19, 2008
    Hi GUYS! PLEASE CAN SOMEONE HELP ME... I'VE RECENTLY BOUGHT A MERCEDES ML280, BUT I WOULD LIKE TO BUY A SAT NAV FOR IT, I'VE SEARCHED ON eBay BUT WHAT MODEL SAT NAV WILL FIT MY CAR????
    PLEASE HELP ME BCOS I AM STUCK!!!! :lease: :lease: :lease:
  15. blubber
    blubber
    Apr 11, 2005
    175
    +9
    johnnykick is correct, it is a simple set of key strokes to get into the advanced menu and then you can set the dvd in motion and dvd region free, as for adding rear screens without the tv tuner you have to get a small device which you can attach to the back of the command and has aux in/out so you can attach screens and dvb tuner, its available on ebay for about 100 pounds
  16. JamieM
    JamieM
    Jun 12, 2009
    I have a new ML280. is there an affordable sat nav I can fit to it that will operate on its screen? Thanks :rolleyes:
  17. Merc man
    Merc man
    Hi, do you have the ebay link? Have tried searching but no luck?
