Men & Motors
Discussion in 'Satellite TV, Sky TV & FreeSat' started by whatdoiknow, Aug 1, 2005.
  1. whatdoiknow
    whatdoiknow
    I was just helping a friend set up their new Panasonic wide screen digital tv and going throught the programmes to show them what they can receive when I noticed they could get Men & Motors.
    I just wondered why I cannot receive this on my Netgem freeview box, and are there any other programmes that can be received with a digital tv that a box cannot get.
    Thanks,
    Martin
  2. madcyril
    madcyril
    May 30, 2004
    1,049
    Manchester
    +94
    M&M's is fairly new on freeview,have you tried re-tuning.
  3. whatdoiknow
    whatdoiknow
    Thanks, I'll give that a try if I can find out how you do it.
    Martin
  4. Chris Johns
    Chris Johns
    Jul 27, 2005
    3
    Suggest you da a STORE channels rather than an ADD channels.
  5. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    It'll probably be gone by the time you get round to it though :(
  6. whatdoiknow
    whatdoiknow
    Can't remember which button I pressed but it re-loaded every channel again, including M & M.
    Odd thing though is that after uploading the latest software when I go up and down the channels with the << >> button when it gets to say channel 8 where there is no programme it won't go past that point.
