Men in Black Region 1
Discussion in 'Movie Forum' started by webgoat, Jan 6, 2003.
  1. webgoat
    webgoat
    I've recently been given Men in Black 2 (region 1) as a gift. When I start the disc up I get a world map with the regions on it and a message that this disc can only be played on an untampered Region 1 player. I've tried using the goto to start on a different chapter but get the same message. I have even tried using my computers DVD to play it but with the same result.
    Has anyone else got this and been able to get around it? Or is this a lost cause?
  2. stubags
    stubags
    I have a Toshiba player. With this it is possible to press stop just before the world map is displayed and then to do a time start by pressing T twice, and putting something like a minute in, and then pressing play. You can then rewind back to the start. If you press stop too early or too late it doesn't work. You didn't say what player you have so this may be no use at all to you (but might be worth a try if you have time search on your player)! Chapter start doesn't generally work because they've coded the RCE stuff into every start of chapter I guess.
  3. webgoat
    webgoat
    It's a Wharfdale 750.
    I'll give your idea a try. Cheers
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,425
    Somewhere in South Yorkshire
    +5,824
  5. alle v
    alle v
    Nov 11, 2002
    211
    19
    Derbyshire
    ...Try loading a normal non RCE region1 disc first then the MIB2 one.
    ...edit
    Just found this though.
    Can the Wharfedale 750 S play region 1 ... ?
    Not only can the 750 S play region 1 discs it also plays RCE discs which the 750 was unable.
    For a great page on all models of the fine Wharfedale 750 go to:
    http://www.dvdtimes.co.uk/wharfedale.html#region1
    So is yours a 750s?
  6. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    The original 750 will not play RCE R1 disks.
    However, all is not lost ! you can buy (at low cost) a new firmware chip that solves the problem. I have tried this in the past and it works.
    take a look at www.dvdchips.co.uk/
    The cost is £20 so its upto you whether the investment is worth it or not
    Russ
  7. Ripco
    Ripco
    Aug 18, 2002
    320
    Scotland
    +3
    When playing my R1 MIB 2, its seems to flick what looks like aspect ratio at various points throughout the film (Maybe at the different scenes) any idea why this would be doing this?
    Thanks in advance,
    P.S. its a Full Screen version being played on a 4:3 43" rptv.
    Ripco.
