memory..which one ?
derby4life
hi guy's.....not sure which memory to get for my pc....found one on ebay but not sure if it will fit ...I've done a scan thing on the net that I'll put a link up for below ...cheers
BRAND NEW IN BOX - PURCHASED FOR £38.00
512MB, 184-pin DIMM, DDR PC2700 Upgrade for the Dell Dimension 2350 Series Desktop
Module Details:
* Crucial Part Number: CT522400
* Module Size: 512MB
* Package: 184-pin DIMM
* Feature: DDR PC2700
* Configuration: 64Meg x 64
* DIMM Type: UNBUFFERED
* Error Checking: NON-ECC
* Speed: 333
* SDRAM Timings: CL=2.5
* Specs: DDR PC2700 • CL=2.5 • UNBUFFERED • NON-ECC • DDR333 • 2.5V • 64Meg x 64
my pc scan ...
http://www.crucial.com/uk/systemscanner/viewscanbyid.asp?id=FBA1706431D926C3&tabid=&pagename=
derby4life
Singh400 said:
Yup, that looks about right too me! :thumbsup:
thanks for the reply bud......just one more thing ....can i just slot it in next to the one already in there i.e 256 slot next to a 516 one ...don't they have to match :confused:
shay0
Memory modules don't have to match and should work fine. You have to be careful with Dell machines though, as they can be tempremental when you do mix memory. Just a note though, £38 does seem a bit steep, but maybe that's just me being a tight arse :)
derby4life
yeh it steep ...its of ebay ...and thats not the price its going for just the retail price :)
thanks all for the reply's
Similar threads
