memory timings
Discussion in 'Computer Components' started by sc1977, Nov 24, 2004.
  1. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    im currently running a 2500xp oc ed tho a 3200 xp on a a7n8x delux motherboard i have 2x corsair 256 twinx low lat ddr 400
    the memory setttings are on aggressive on the bios
    can any body tell me the best timing settings and what is reliable?
    stu
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,469
    Southampton
    +188
    Question is are you trying to overclock?
    If you are I would think you would achieve cas2 7-2-2-2 or even 6-2-2-2. To be honest all systems arent equal so the only way to really find out is lower them gently and stress test by playing a game or do as I do and run 3dmark 3 or 4 times.
    If you want just plain stable then CAS2 8-3-3-3
  3. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    it was on 6 3 2 2
