memory sticks
Discussion in 'PS Vita Forum' started by elliothand, Mar 21, 2006.
Tags:
  1. elliothand
    elliothand
    Feb 20, 2006
    410
    Essex
    +12
    Hi, I'm interested in getting a memory stick for my psp but does anyone know when the 4gb ones will be released?
    If I don't wait am considering one of these and so would like to know what your opinions are, what the differences are and why the differences in price? Also where are the best places to get them from?
    Sony 2GB Memory Stick Pro Duo - £77.95
    http://www.amazon.co.uk/exec/obidos...8-2/ref=sr_8_xs_ap_i2_xgl/202-7806830-2168607
    SanDisk Ultra Il 2GB Memory Stick Pro Duo - £95.02
    http://www.amazon.co.uk/exec/obidos...8-3/ref=sr_8_xs_ap_i3_xgl/202-7806830-2168607
    Sony 2GB MS PRO Duo MSX-M2GS - Official PSP Memory - £77.95http://www.amazon.co.uk/exec/obidos/ASIN/B000BU2FKC/qid=1142901654/sr=8-5/ref=sr_8_xs_ap_i5_xgl/202-7806830-2168607
    Thanks for all your help!
  2. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    University: Lancaster, Home: Cambridgeshire
    +200
  3. Dick
    Dick
    Feb 12, 2004
    I have read the sandisk is a bit faster than sony, but the normal sandisk, not the one you mention, which is the ultra. That one is the most expensive, but should also be the fastest. I am very happy with my sandisk pro duo gaming.
  4. elliothand
    elliothand
    Feb 20, 2006
    410
    Essex
    +12
    Thanks for the help!
    Does the speed make much of a difference? Is it just the time to access the files or do the files lag etc if I get the slower ones, eg if I were watching compressed videos would I get slow down?
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    This article is very good to highlight the difference between Sony and Sandisk.
  6. elliothand
    elliothand
    Feb 20, 2006
    410
    Essex
    +12
    That article was really interesting! Thanks for that, will be going with the san disk one now!
  7. hardiz
    hardiz
    Mar 3, 2005
    247
    +14
    can the psp handle more than 2gb sticks? I am certain i read some where that the duo cards had a limit of 2gb or the psp had a limit of 2gb??
  8. RobP
    RobP
    Feb 20, 2005
    14
    Memory Stick Duos have a Limit of 4GB. Hopefully, as some of the comments suggest, Sony could release a firmware update to allow more memory, I guess it's just an issue of how the interface works.
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    8Gb is the limit so far. Click here.
  10. captain kirk
    captain kirk
    and dont forget if you convert ya stick to fat 32 you should get another 3rd of capacity out of any memory stick.
    Also i dont think it makes a difference as to how large your storage capacity is, think the psp is not suppose to be just a portable playstation - think sony have bigger ideas for it.
    therefore :- 2 gig - fat 12 , 2 gig - fat32 about 2.900 gig.
    did you know you can get 353 mp3`s at a bit rate of 128 on one 2 gig stick?
    hope your enlightend.
    click....
  11. stormjai
    stormjai
    Nov 15, 2003
    331
    Bromley
    +3
    How do you format to FAT32 ? leave in PSP and format it vis USB from PC, or format in PC card reader?:confused:
    Ta
  12. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    All you have to do is plug your psp to the computer and back up all your psp files. Right click on the drive it shows up as click format go to file system and select FAT32.Then copy your files back.This file system load faster and small files take up less space (in as simple terms as I could put it).
  13. figoagogo
    figoagogo
    Mar 29, 2005
    8,188
    +579
    Can you someone confitm that this is safe - who on here has formatted the MS in this way? Any problems at all?
  14. Hawklan
    Hawklan
    Oct 20, 2001
    6,793
    Essex
    +325
    I've formatted both a 1 gb Sony and 2 GB Sandisk with no problems
    I didn't copy over my old file structure - I just reinstalled any applications needed after I'd setup the directory structure manually via a PC
    Many thanks
    RON
