Memory Stick Advice
Discussion in 'Photography Forums' started by superdon, Dec 9, 2004.
  1. superdon
    superdon
    Dec 31, 2003
    1,715
    48
    +65
    Just waiting on dleivery of my girlfriends Xmas pressie (Sony W12) and wan to buy some extra memory to go with it.
    I understand the camera will work with both Memory Stick and Memory Stick Pro. I know Pro is faster, but will this only affect things if I am using video on the camera? We are not going to use the camera for video much, if at all, and I dont want to buy the Pro if I dont really need it.
    Also, where is the best place to buy from? I see there are some good deals on them on ebay, but mostly shipped from Hong Kong. I was looking at 128mb or maybe 256mb.
    Also, whats the Duo all about and can it be used with the W12?!?
    Cheers for any advice.
  2. DJW
    DJW
    Aug 29, 2002
    965
    16
    www.Ebuyer.co.uk are a good bet. Extra write speed is only of use for multiple shots short bursts....if camera offers that. Sounds like you don't need it.
  3. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    Hi Superdon
    I recently got the W12. Very good camera!
    I bought 256 'Sony' branded memory stick PRO. The PRO is replacing the higher capacity non PRO sticks, and these will be the only ones of 256 + available after a while.
    The advantage with the PRO sticks is the faster transmision speed, which enables video recording at 640x480 - A very good quality moving image with high resolution. Very nice feature IMHO, and not that common on digital cams at this price level. It makes no difference and no benefit to still images, though.
    I got mine for £37 inc shipping from a guy on ebay in the US. Was half the shop price.
    I wouldn't get anything less than 256mb, if I were you.
    The DUO is a smaller card (half the length) which is the only size that fits certain Sony products (typically hand held devices). You can use this in your camera, providing you use the 'adapter' thingy that may / may not be supplied with a DUO card.
    I specifically wanted to avoid the DUO as I felt it was more fiddly.
    If you want your memory for xmas, you'll be too late for deliveries from the US / Hong Kong. Instead try here
  4. superdon
    superdon
    Dec 31, 2003
    1,715
    48
    +65
    Cheers for the help.
    I've been bidding on ebay for some (both UK and foreign based) and am just missing out on all of them! There seems to be some bargains on there though, missed out on a brand new 256mb Sandisk Pro card that went £16! Will keep trying though.
  5. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Good luck with the ebaying - hope you don't get a dud stick! Definitely go for Pro though, the 30fps video is worth paying the (quite small) extra for. If your TV has a front AV port you can play off the camera like a camcorder as they include a composite lead to connect the camera directly.
    I seriously didn't expect to use the video either and i now really like it. It's a nice to have that I infrequently use, but definitely prefer to have it there when I want it.
  6. superdon
    superdon
    Dec 31, 2003
    1,715
    48
    +65
    The camera was delivered this morning - even though PC World still think they are processing the order?!? Maybe they will send me another :)
    I've had a quick look at it, but cant really have a proper play as I need to wrap it up ready for Xmas day.
  7. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Don't forget to charge the batteries when it's open!
  8. Paulholio
    Paulholio
    Be careful when getting them from ebay ans definately make sure its an official sony product. I know a few people who have been getting duds. I ended up getting my girlfriend one from hifix
  9. superdon
    superdon
    Dec 31, 2003
    1,715
    48
    +65
    Well managed to get one in the end. Its a UK supplier, and is a genuine Sony product. Its a standard memory stick rather than pro, and only 128mb, but only cost me £15 all in. I figure we can buy another one after Xmas some time.
