MEMORY Compact Flash 8 GIG £31
Discussion in 'Photography Forums' started by cruncher75, May 3, 2007.
  1. cruncher75
    cruncher75
    Nov 1, 2003
    1,455
    southampton
    +119
    Not sure if there any good but only £31 [GOOGLE]http://bigmaggot.co.uk/MEMORY-Compact-Flash-8-GIG-BRANDED-CF-CARD-Retail-Boxed-pr-205.html[/GOOGLE] using the £10 off google voucher
  2. hot-fuzz
    hot-fuzz
    Dec 13, 2005
    6,086
    Hampshire/Surrey, UK
    +593
    CF cards are getting cheaper by the day it seems.
    Trouble i have with CF cards that big is in that if i have an 8Gb card, then it would suggest i need more than 2Gb worth of photos on 1 card. Therefore i would have over 2000 photos on 1 card and i would never do that just in case i lost it, broke it or just plain couldnt find what i wanted on it.
    I think sticking to 4 x 2Gb will do me so i dont run the risk. Plus i can use 1 card for each situation (got a wedding at the weekend and will use a blank card so as to not use up my "family photos" card).
  3. Peakoverload
    Peakoverload
    Dec 1, 2003
    923
    43
    +198
    Those cards are pretty dreadful, really slow. If you only shoot jpeg then that may not be a problem, shoot RAW though and ouch!
  4. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +59
    If one big card fails or goes missing, you lose a hell of a lot of photos. I tend to stick to a few 2gb myself. Those size cards are only useful if you're using a high res digital back.
