Memory Cards for Boot O/S
Discussion in 'Computer Components' started by Monty Burns, Sep 8, 2007.
  1. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,869
    Londoner living in Bahrain
    +140
    Hi Guys,
    i've finaly given in and decided I need to build myself a new MCE pc.
    I'm trying to make a really quiet HTPC to replace the old AMD twin raptor box im currently using.
    Question is, are Memory Cards fast enough and big enough yet to be used as the boot partition i.e. contain JUST the o/s ?
    Thanks in advance! :thumbsup:
  2. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    You could always get a solid state hard drive - but yes, they are, as long as you don't want vista!
  3. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Yes they are but remember that Flash based Ram has a limited number of writes (usually between 10k and 100k times) depending on manufacturer.
    If you had one with a lower write tolerance the OS could nuke the drive faster than you may think.
  4. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,869
    +140
    Hey guys
    thanks very much for that! Your right about memory card soloution Uri - I found this out after some research.
    Now for the good news, Sean T is right. SSD's are the best way to go and these seem spot on :thumbsup: And the news gets better. There are a couple of 32gig SSD's out there for around £300 - not cheap by HDD standards but still acceptable for me. And now for the even better news, Samsung are about to release a 64gig thats expected to be about the same price(ish)... result!:clap:
    Thanks again guys for your info, much appreciated!
    Uridium - don't spose you know where I can get a cheap rear seat cowl for my Sp1 do ya? Mine flew off down the A40!!! :D Honda want 130+vat and i've had no luck with breakers or ebay :mad: Bu&^ered if i'm paying 130 for a bit of plastic - principle ya know.
  5. Decadent Fool
    Decadent Fool
    Dec 27, 2006
    546
    28
    Shropshire
    +33
    Interesting thread; would really love a move to ssd :)
  6. Embarker
    Embarker
    Apr 19, 2004
    1,689
    Garden of England
    +71
    Scan have a samsung 4gb solid state drive for just £56.99 - and free delivery for forum members.
    Now that very tempting for non vista users...............
    Only £146.88 for the 16gb and £217.38 for the 32gb.
  7. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Anyone found a reasonably priced SATA 8 gig - don't need 16 as will be using RAID 0, and it's only for the boot part. in vista? Has to be SATA, mobo doesn't have IDE raid and don't want an external controller for a boot drive....
  8. southdownswolf
    southdownswolf
    Oct 3, 2007
    127
    +11
    We are experimenting with SSD's at work for our high end systems (CCTV), however they do seem to be quite slow compared to sata drives. I would imagine that they may be okay for a media centre. What will you be doing for storage drives though? If you are using SATA/IDE drives, which you would need to if you are storing video, surely they would cancel out the effects of using the SSD's? I presume you would be linking it up to a NAS to negate the noise?
  9. MikeC
    MikeC
    Mar 14, 2001
    225
    Northants,UK
    +10
    You don't necessarily have to use 'proper' hdd's - see this article which shows how to use Compact Flash cards instead.
    I bought a cheap 1Gb CF card plus an ide adpator off e-bay and gave this a go.
    Amazingly it worked, albeit it took 10 mins to boot up and was a bit slow, which I took to be due to the slow speed of the CF card.
    Also had to use a cut-down version of Win XP to fit on the card.
    Not sure I'd recommend it TBH...
  10. Embarker
    Embarker
    Apr 19, 2004
    1,689
    Garden of England
    +71
    For me, all video's, films, tv series, music, are stored on a server and are streamed to my HTPC. This even works for 1080p HD DVD/Bluray.
    Even the quietest drives can still be "heard" and produce more "heat", so this would allow for a "cooler near silent" HTPC.
